redline4
I'm huge in Japan
4:40 AM
Rosholt Wisconsin
So, months ago I offered these air ratchets up for anyone who wanted them for the price of a donation to any veterans organization. The purchase of a Buddy poppy would have sufficed..
Both work but need rebuilds. The 3/8" Snap on would likely need to get sent in to them. The I/R can get parts online I know.
I'm tired of moving them around on my bench.
If anyone wants one or both, let me know.
I'll give it until noon tomorrow and then I'll cut them with the torch so that cocksùckīng piece of shīț Lord of the wrench can't dig them out of the scrap bin.
cuinrearview
Handy dood
5:40 AM
Dowling, MI
@Woodpecker
Fab up some sort of coupler. With your Makita compressor, you could pull dents anywhere.
Tor R
Novice, Leg model #2
11:40 AM
Mandal
Not my day for porting, polished the exhaust ports up really well, and ended up changing the EX timing without noticing it then and there.
My eyes are no longer what they were, and the years where I didn't port a single jug probably play a part too.
I'm going to save these 353 jugs with machining and epoxy IN since I drop them more than I really wanted to. One was my own so it doesn't matter, the other one will be my own project.
For the customer it will be a 346 ne nos kit, have no ambition to lower my reputation.
I'll probably take it a little more calmly and carefully when I port it, and go back to the basics with marker and paper card.
Only the Tony
4:40 AM
I thought you retired from your delivery stallion?
Have to be 55 and 20 years full time for insurance from the union. Be 52 in January so little over three years.
Morena E Hoas.
Ordered me a fruit picker so I can reach some higher fruit and not always have to go for just the lower ones. For some reason it reminded me of you.
jacktheripper
Papa Squat
3:40 AM
Wyoming
What was supposed to be a quick easy job after work has now turned into a three evening ordeal. Went to replace the water pump on my 1995 f150 302, and broke two studs off that go through the water pump and timing cover into the block. Tonight, I went to pull the timing cover and found that the studs were frozen in the holes that they broke in where they pass through the timing cover. Looks like dissimilar metals fused together. Had to crack out the bolt holes in the timing cover to get it off. Replaced the timing chain set while I was at it tonight. Now I need to order a new timing cover to get this back together. Looked it up online and apparently this is pretty a common problem on these old Small Block Fords.
cus_deluxe
terms of service violator
5:40 AM
Michigan
Good morning girls, whatcha doin today.?
Its less wind here today,so I guess I’ll be picking apples off the floor because yesterday it was gusting 45\50 mph here.
No low hanging fruit here Tony, 😉
im gonna go rent the best stump grinder in the whole county today. also happens to be the chittiest stump grinder rental in the whole county since its the only one. good times
