Kiwioilboiler
346 Pic Examiner
- 11:24 AM
- Apr 20, 2020
- Marsden Pt, NZ
Like Jaxon helps you?...Get another push mower and have E help.
Aliasundercover J Imapseudonym JrI'm implicating all of you. I'm gonna need a list of everyone's aliases just in case they ask.
Well my name is JoeI'm implicating all of you. I'm gonna need a list of everyone's aliases just in case they ask.
Stop by the seamstress to get the violet pants repaired?good morning folks,
Fewer plans for the day, I need a hose clamp, get the right pressure in the tires, go to the neighbor's and steam the engine since everything is open.
I have to order some small parts too.
Heck, I mow almost a half acre with a 22" self propelled push mower
Can't hide poverty
I have 2 walk behind mowers, a 30” Toro that can really move and a 21 Ariens that needs some work. I will pick up a spark plug and carb kit for the Ariens and get it running but the greatest issue I am having is the underside of the mowers clogging with grass and not discharging well enough. Spent an hour on the Toro last night and because the grass never gets a chance to fully dry out I am constantly dealing with clumps of grass blocking the discharge.Get another push mower and have E help.
That’s just Minnesota nice. Totally normal.
I’m assuming that with the grass being extra long, you have already raised the deck to the highest setting, and are mowing it at that height, and then dropping to your regular setting and mowing again.. That helps prevent clogging.I have 2 walk behind mowers, a 30” Toro that can really move and a 21 Ariens that needs some work. I will pick up a spark plug and carb kit for the Ariens and get it running but the greatest issue I am having is the underside of the mowers clogging with grass and not discharging well enough. Spent an hour on the Toro last night and because the grass never gets a chance to fully dry out I am constantly dealing with clumps of grass blocking the discharge.
I appreciate the input on a 48” triple blade deck, I will look at those. JD is the dominant brand locally, a little further away Cub Cadet or I can hit my usual dealer for a Toro. Will see what Marketplace can turn up too…
