Bilge Rat
11:49 PM
savannah georgia
It's down under so it has a separate "drain plug" for the filter and then another tool to actually remove the filter body, plus the fiddly little drain nipple
At least the tool is a nice even size
:rolleyes:
64.3 mm, and before you bother converting it to freedom units it comes out as a weird ass number there too
It ain't metric, it ain't Murican, so what measuring system haven't we roasted...
There is a British standard or unified sized set of wrenches that were used on some British cars.
You needed American, metric, and the british sizes to work on a jag.
JoeDirt
Piss Jug Tosser
11:49 PM
United States
:rolleyes:
Now that is dumb.
lol probably 2 3/8 or close to it
We will wait on the metric mathematician
Right at 2 and 17/32".
JoeDirt
Piss Jug Tosser
11:49 PM
United States
Need to replace the auxiliary transmission fluid pump on the F150. It is used to keep pressure in the transmission for when the auto stop/start system engages. I keep the stop/start system disabled most of the time but I still want it to work the way it supposed to. It's an easy part to change out, but it has to be bled electronically. I tried using my Chynuh scan tool to see if it has the ability to perform the bleeding function, but kept getting an error mesage. So I updated the software on it and it seems to be working now. Saves me a trip to the dealer.
beaglebriar
The Peanut Gallery
11:49 PM
Warren Center, PA
redline4
I'm huge in Japan
10:49 PM
Rosholt Wisconsin
I hear ya. Nice to be outside doing whatever this time of year.
My old fence was mostly boards which you would think is easy to remove but even that was a pita.
I found 2 strands that went almost the full 50 yards I did today and were both buried probably 2" into the ground.
My west property line was like this too. They must have gotten a good deal on wire because they were not shy with it.
Loony661
462’s 4-LIFE
10:49 PM
Winona County, MN
What were they trying to keep in with all that wire??
10:49 PM
