JoeDirt
Piss Jug Tosser
1:36 AM
United States
depends
you pick
Neither is good but I'd rather be awoken by a car fire.
Don't even get me started on the newer Toyota Tacoma cartridge filters
Fukking morons
My F150 has one. Doesn't really bother me. They filter the same. Easier to inspect the cartridge type for anything that shouldn't be there. And it's mounted on top for less mess. The canisters are easier to spin-on, spin off though. The semis are starting to use the cartridge types.
3browns
9:36 PM
Fishhook, Alaska
It's not the cartridge I object to, its the moronic way they implemented it
First the filter body mess is plastic and you have to get an aluminum bodied one for long term durability, you need a whole new filter wrench setup, then there is the plastic gizmo you have to force up into the "drain" hole and you have to "milk it" to get the filter to drain before you take the cartridge off and not all of the filters come with that gizmo
Just not very thought through if you ask me
JoeDirt
Piss Jug Tosser
1:36 AM
United States
Mine is plastic. Right on top in the front. Takes a 1 inch socket. Haven't had any issues with it rounding. Three o-rings that take a minute to swap out with a pick tool and the new filter cartridge gives a nice, positive "click" into place. I haven't seen the Toyota setup so I can't comment on it.
1:36 AM
Pictures or videos of the milking
5 million birch, alder, and willow trees in sight and this azzhole decides it needs to munch on our expensive maple trees
It’s softer lol
3browns
9:36 PM
Fishhook, Alaska
It's down under so it has a separate "drain plug" for the filter and then another tool to actually remove the filter body, plus the fiddly little drain nipple
At least the tool is a nice even size
:rolleyes:
64.3 mm, and before you bother converting it to freedom units it comes out as a weird ass number there too
It ain't metric, it ain't Murican, so what measuring system haven't we roasted...
1:36 AM
:rolleyes:
lol probably 2 3/8 or close to it
We will wait on the metric mathematician
