- 9:29 AM
- Jan 17, 2016
- Wv
What gets me is the only solution they have is to replace with the same defective part'sUnreal!
If I was him I'd demand a different brand they offer several brands at that dealership.Mahindra doesn’t have a very good reputation
One guy near me traded his in
25 hours on it and as you said front end issues
His was making a noise and he only mowed with it
A buddy’s dad has a 35/40 hp one and it might have 1000 hours on it now and it is on its last leg transmission issues
He had me to rebuild the backhoe stabilizer cylinders and mahindra couldn’t get him the right parts even though he bought it there
They had the serial number for tractor and backhoe and the stuff they gave him was not right
I ended up taking the pieces to a hydraulic shop
So mahindra isn’t a tractor company I’d be buying
Best to take a loss and find something different
Dat downspout got winning written all over it!
…they wouldn’t have it no other way.What gets me is the only solution they have is to replace with the same defective part's
Now I ain’t much of a tractor man, but does “running with the wheels turned out” refer to no positive camber (toe-in) on the front tires, or the rim/dish orientation?Is this what your after @Tor R ?
Everything is *s-word now my nephews new 4x4 mahindra 26hp the front end literally exploded after it locked upMassey Ferguson 4355 Injection Pump (REMAN) | Thoroughbred Diesel
Freedom Series Massey Ferguson 4355 Injection Pump (REMAN) available at Thoroughbred Diesel.www.thoroughbreddiesel.com
It just has about 40 hour's on it
We had it several miles from a road on a ridge the mahindra tech said *f-word it up it's under warranty we'll fix it
we can't load it
Run it with the bucket down and slide it off the ridge to the trailer
We did it ripped the pumpkin apart and blew gears thought the housing
Noe there's no replacement parts in North america for it
The dealer is trying to get permission to pull the front end off a new tractor.
Here's the crazy part
Mahindra says the tractor wasn't designed to run with the wheels turned out
It places too much stress on a pin in the front end?
Well the dealer delivered the tractor with the wheels turned out
It's a design flaw I told my nephew to ask for a different new tractor
But his was 17k 3 year's ago
It's 31k for the same tractor now.
I would assume dish of the wheels.Now I ain’t much of a tractor man, but does “running with the wheels turned out” refer to no positive camber (toe-in) on the front tires, or the rim/dish orientation?
That looks to me like a Radon fan vent.Dat downspout got winning written all over it!
He ran it as delivered from mahindraNow I ain’t much of a tractor man, but does “running with the wheels turned out” refer to no positive camber (toe-in) on the front tires, or the rim/dish orientation?
dish orenitationNow I ain’t much of a tractor man, but does “running with the wheels turned out” refer to no positive camber (toe-in) on the front tires, or the rim/dish orientation?
kubota says not to fill the front tires because of rotating mass and extra wear to spin the tiresNow I ain’t much of a tractor man, but does “running with the wheels turned out” refer to no positive camber (toe-in) on the front tires, or the rim/dish orientation?
exactlyA tractor should be built to be loaded to the gills, hooked to an immovable object, and chew all 4 tires down to the axles…like they used to. Shoot, my 6x6 will…
I really have never heard anything bad about them but online there's tons of complaintsMahindra doesn’t have a very good reputation
25hp is the limit now on the regen garbageI really have never heard anything bad about them but online there's tons of complaints
It's a common theme front end or drive line issues
He'd bought this one because it doesn't have the exhaust regen or whatever it's called.
I've run my neighbors new 60hp mahindra for him all this year no issues
He's in too bad of shape to run it anymore.
