Lnk
Stock Chainsaws do not suck!
- 1:40 PM
- Oct 12, 2021
- East, TN
Dremel through the outer race with a mini disc enough to split with a chisel. Repeat all the way through. Inner race will slide right off once split. Good luck.Yes sir. In normal situations that would work but there's no clearance between the bearing and crank on the PTO side. The picture is deceiving there's actually less of a gap than it appears. My little puller normally works slick but I'm thinking that I might have to weld something to the side of the bearing to grab on to....or something else creative. I'll get it just gonna take a minute. Flywheel side is no problem...
