redline4
I'm huge in Japan
8:05 PM
Rosholt Wisconsin
It's a diesel Ed, and currently has a hole in the intercooler. No butterfly to create vacuum, but as you say some sort of mass air imbalance is being picked up by the ecu.
New IC tomorrow or Saturday and that will stop my stupid questions.
On this subject anyway. :)
Duh, I forgot and thought it was a gasser.
Any "unmetered" air in and they get funky.
timg
9:05 PM
Keystone State West
Code is P00BD. Air flow meter voltage out of range.
No throttle over run. When you are off the accelerator pedal, braking even, coasting down hill. Ie, minimal exhaust gas to drive the turbine to drive the Kompressor for the vnt to make any boost.
Is this a Tier4 interim class engine Adam. If so it may have an exhaust pressure sensor in exhaust manifold. Our 4 Finals do not but early Interims did. With a boost leak carbon can build up in exhaust stream and because of poor calibrations plug this sensor. I didn't look up your code. Would need some truck/engine info to do so. Just a wide left stab here guy
Also we have a test called MAF Drift test. It checks Mass flow, charge temp//pressure, and exhaust flow parameters. Is there such a test for this Isuzu?
Kiwioilboiler
346 Pic Examiner
1:05 PM
Marsden Pt, NZ
Oh Timofee, this Isuzu is a Ford Volvo Mazda. :)
Duratorq slash PowerStroke 5 cyl diesel. P5AT.
Mines the earliest, simplest version.
GCJenks204
"Special Buns"
8:05 PM
Winnipeg, MB
Morning / Evening All.
Sun is coming up and temps above melting already, should be a decent day. Need the ground to thaw some, another Colorado low headed in on the weekend with another 1 1/2 of rain. Rivers, streams and ponds are already over loaded, need some else for the water to go.
JugHead27
I'd rather be called gay
10:05 PM
NS
I have a standing job offer in Halifax, my wife won’t even consider it as there isn’t enough heat in the summer. Our winters may be cold but our summers get hot too.
Don’t get me wrong, NS can see 30c summer days, but you go within 5km of those shoreline and it’s much cooler. Halifax is fairly warmer during the summer in comparison to southern NS. We get much more fog etc
Honey? We have a bee hive. No doubt about it being nature's most perfect food.
natures perfect food is a juicy sirloin steak medium rare
ray benson
8:05 PM
nw indiana
Good morning. 41°F/ 5°C going up to 52°F/ 11°C. Fertilizing the church grass today. Going to run a lawn roller around the parking lot to tamp down the edges where the snow plow chewed into the grass. Raked it out best I could a few days ago but it needs to be evened out.
