9:26 AM
I like a spool over a real automatic locker if on the street. No surprises when letting off the gas in turns ect. You always know how a spool will act. And strong as fork. My 74 bronco had 4:11's and rear spool. No issues on the street outside accelerated tire wear. Worth it.
That spool will put you in the ditch on a wet road though. I'd rather have an open rear end in my street cars. Drag race machine.....spool.
I had a 72 Duster with a set of 4.56 gears, mini spool, 340, 4 speed. With cheater slicks it pulled so hard that it cracked the windshield, and distorted the quarter panels to the point that the doors became hard to shut. I also nearly crashed it a few times on wet roads. LOL
Lightning Performance
10:26 AM
East of Philly
Yeah... a spool is just great for the street rod. Fat tires, no weight and you can't drive it in the rain or wet. I been in the WV and PA mountains too many times when rain or snow was on the mountain. Spools wait it out on the incline because they have no choice. You never drove a serious road car then. Spools suck and are illegal in half the cars I used to build for street, street/strip and other classes. Being Dqued for sometime as minimal as learning to build a proper differential was never and option for myself. Setting up an open rear with a bit of creative machining to the carrier and knowing how and why it works like magic is the better option. You can put in one clutch pack only or two but they only last so long using an open diff setup. The best option is buying a heavy duty muti-spring clutch pack and removing all the springs imo. If you set up the posi correctly it will work just fine with no chatter and no drag. The thing will be smooth with the right additives. You wouldn't know it had a spool or posi when you pick up the front tires. If it goes straight with same setup as a spool my job is done. Staying on top of a posi is work like adjusting valves for the power tour and chit like that.
Do you know why guys loose parts in a diff, repeatedly, most times?
timg
10:26 AM
Keystone State West
Timing belt service?
No sir that was last fall. All through the right wheel well. Belt, water pump, adjusters, and what nots. It had 132K at that time and was due. Again saved money and burnt vacation on that job. Pulled the front to access power steering cooler hoses. I definitely miss my 78 F250. Everything just seemed less involved for sure.
10:26 AM
East of Philly
Yup
We had a guy did a blast in his fresh burn out one night at Mcy Ds.
Orange Hemi Valiant twisted the driver side door hinges and spider webbed the windshield. He called us every mfer in the book for beers consumed and egging him on while lol.
Fun times!
427 Mustang was deadly on the wet with a spool.
Camaro was a touch better.
Tiny Mopars, um NO!
You can't make that chit up.
Saw Collector
OPE Member
10:26 AM
Here
An automatic locker or tight limited slip can get squirrelly on snow and wet too. I never had issue in rain with the bronco and I never drove it in winter. Best of both worlds are ARB air lockers or OXtrax cable lockers. And whatever electric lockers there are available. Off when you want, spooled up when you want.
Saw Collector
OPE Member
10:26 AM
Here
Did ya see me state "serious" street car. No. Early bronco. Light weight. Small block Ford built for off-road. low end. Stick. Never an issue driving it on the street to and from the dunes up the highway at 70-80 or to and from trails. Illegal? Yep. Gave zero fuggs. You think a cop has a clue? I drove that bronco in three seasons here for a couple years that way. Even to work and back in the city 20 miles away at least once a week. Rain or shine. No issues.
9:26 AM
That sounds like the ticket !!!!
USMC615
Fapper Fi
10:26 AM
Mid-Georgia
Ol' Puddin be out soon...he prob needing his rear end rebuilt. Kenny, you up to the task? Lol
9:26 AM
Bill Cosby was just let go. Legal technicality.
They infringed on his fifth amendment rights according to PAs state DA.
Shame to let that predator out again. Maybe someone will get him soon. The guy is a POS!
Edit
Fixed
Ain't that some bullshít
9:26 AM
My first car was a 75 Duster with a slant. When the first rear end shelled out we scrounged one up from a junk yard. It had a half ass busted limited slip that chirped the tire when backing up and made the car even slower than before.
Good time.
10:26 AM
East of Philly
Yep. Installed a truetrac in the front of my TJ. Very nice unit and no clutch packs or cones to wear out.
Guys with 44" tires loved truetrack dana 70 front and back. Like wheeling with dog! 4x4 with thought lol. They go like wow in the mud. Ask me how I know. This guy never ran anything bigger than a 12bolt with 36" tires and no power adders 400-450 hp 5.7 sbc. Nothing wild but broke eleven back rears and three fronts in two years. It was weekend truck mostly, tow boats or haul scrap.
Best bet for the street and off road overall is the Eaton truetrack No springs in the diff is my choice for big power. Less failures overall with less parts. You can take out a lot of heat prone failures, fact. Less is more in there.
Twelve springs is never good imo.
