12:06 AM
Wix is junk. I use cat 1r-0749 if people don’t convert to my custom microglass filters. But fass got smart and started using micro glass so you can now use their elements in cat 1”-14 thread pitch standard base
your custom ?
Kiwioilboiler
346 Pic Examiner
5:06 PM
Marsden Pt, NZ
To actually answer your first question. I treat year around for cetane and anti gel because I don't always fill my bulk tank in the fall. All depends on my usage. It can get in single digits to below zero here in winter. I want that added pop of extra cetane and no gelled fuel. By dosing year around I'm covered. Same with fuel stabilizer. I put it in every can I fill even knowing much will be used long b4 the stabilizer will be needed. But, I don't have to wonder if that fuel setting there over winter is stabilized or not because I know it is.
Good answer.
Kiwioilboiler
346 Pic Examiner
5:06 PM
Marsden Pt, NZ
well you are our resident knowledge on this stuff so what do you say to keep injectors clean
Fuel filtration. I’ll answer for him
What Pat said. Keep your fuel clean and dry (no water).
Factory grade filters changed on time. No rocket surgery for me. My wagon is not hugely turned up tho.
12:06 AM
So both my tractors just have little inline piddly fuel filters from the factory. Should I think about putting a fuel filter/ water separator setup on them? Or is it unnecessary for my sized machines?
mine just has the factory glass one on it also
PA Dan
FYD
12:06 AM
White Oak PA
he never gets pictures
just the aftermath
Well....that enough...dik
