- 10:39 PM
- Feb 5, 2016
- grafton wv
lol and who would that beI was gonna ask the same thing but if I did someone would say I’m stupid
Mine also has the cp3 but there are some things you can do to make the cp4 only destroy itself instead of everything in its return and pressure path so to speakso you do know where they anchor at and cut the line to the said anchor ? lol
mine has the cp3 pump
ive heard the cp4 isnt so forgiving
the tree thing is a myth @PA Dan said so
Hows the fog horn build going? We operational yet?I was gonna ask the same thing but if I did someone would say I’m stupid
i just dont want to buy injectors as often lolWhy y'all think you need more cetane? Winter diesel has more Pop blended in. Just refill your bulk storage then. How fast a Kubota tractor gonna go anyway?
as in what ?Mine also has the cp3 but there are some things you can do to make the cp4 only destroy itself instead of everything in its return and pressure path so to speak
Yea it works lol the first version at least. I want one that plays a 5 note diminished 7th chord to sound really terrifying now lolHows the fog horn build going? We operational yet?
needs more workYea it works lol the first version at least. I want one that plays a 5 note diminished 7th chord to sound really terrifying now lol
Idk what any of that means... just want people sitting at green lights staring down at their phones to soil their britchesYea it works lol the first version at least. I want one that plays a 5 note diminished 7th chord to sound really terrifying now lol
An isolation block on the fuel control actuator that keeps its supply isolated from the crankcase section of the cp4 so that when the cam followers lock up the metal shavings only go out the return line And not to the injectors, then a 2 micron filter on the return line back to your tank so the whole system isn’t contaminated.as in what ?
cetane and lubricity are different cuz.i just dont want to buy injectors as often lol
Look up Leslie rs5t. Train horn. A common freight train horn designed to play that chord and sound more terrifyingIdk what any of that means... just want people sitting at green lights staring down at their phones to soil their britches
I agree lolneeds more work
kinda weak lol
well you are our resident knowledge on this stuff so what do you say to keep injectors cleancetane and lubricity are different cuz.
Yep that'll workLook up Leslie rs5t. Train horn. A common freight train horn designed to play that chord and sound more terrifying
Fuel filtration. I’ll answer for himwell you are our resident knowledge on this stuff so what do you say to keep injectors clean
Yesh! Yaaaash!Yep that'll work
lol id still like his answerFuel filtration. I’ll answer for him
To actually answer your first question. I treat year around for cetane and anti gel because I don't always fill my bulk tank in the fall. All depends on my usage. It can get in single digits to below zero here in winter. I want that added pop of extra cetane and no gelled fuel. By dosing year around I'm covered. Same with fuel stabilizer. I put it in every can I fill even knowing much will be used long b4 the stabilizer will be needed. But, I don't have to wonder if that fuel setting there over winter is stabilized or not because I know it is.Why y'all think you need more cetane? Winter diesel has more Pop blended in. Just refill your bulk storage then. How fast a Kubota tractor gonna go anyway?
Wix is junk. I use cat 1r-0749 if people don’t convert to my custom microglass filters. But fass got smart and started using micro glass so you can now use their elements in cat 1”-14 thread pitch standard baselol id still like his answer
i run wix filter and it was about 50 bucks and i dont feel like changing it in a short time
plus if i buy another to be a play truck later i want to already have some good ideas
How often are you called stupid on here? Who calls you stupid?I was gonna ask the same thing but if I did someone would say I’m stupid
