- 10:23 PM
- Mar 7, 2019
- Keystone State West
You move around well for a big man. A little less crack next time @Pa.Dan.Well....that enough...dik![]()
Sorry brother that was for the dik!You move around well for a big man. A little less crack next time @Pa.Dan.
You’re goodallison 5 speed
that is dans favorite pictureYou move around well for a big man. A little less crack next time @Pa.Dan.
I’m on trans number 3 in 150000 miles lolallison 5 speed
lol i was at about 25000 pounds friday and saturday and it did go thereYou’re good
but you drive dodgeI’m on trans number 3 in 150000 miles lol
Holy yikesI’m on trans number 3 in 150000 miles lol
Dall is running the 1000. Same trans with different planetary gears. I’m running 68rfe dodge junkSo you boys running the 2000 Allison??
The only stuff that I have put in my fuel is the Power Service fuel treatment. https://www.fleetfarm.com/detail/po...6193?Ntt=Diesel Fuel Supplement +Cetane Boost
Every time the barrel gets filled I throw a bottle in. I had never heard of blending in ATF or 2-stroke oil until in came up in this thread.
1000 allisonSo you boys running the 2000 Allison??
evening slacker
i dont want to mix in the fuel but i wouldnt mind something to keep injectors clean and working goodI’ve heard of guys dumping in a couple qts of used oil
Have it all gone by next change
My thinking was that is contaminated fluids
If I burn it, it will be on the brush pile
Sent from Hoskey hilltop
If I tare up this beefed up 68 I got now I’ll be putting an Allison in my truckCopy, I had a 2000 In my last service truck. Never had any issues with the 6.7 and weight. But this truck has the 3500 with the 6.7. Definitely bullet proof hardware for hauling and weight.
Never do this! It must be heated and centrifuged to get asphalts out first then mixed. I can tell you a common rail will run on 30% mixed with usld just fine if it’s got the egr and dpf deleted though. 80% if mixed with gasoline but this takes a lot more refiningI’ve heard of guys dumping in a couple qts of used oil
Two of my friends own their own diesel repair shop. One is the trans guy. Was the Allison guy at Valley truck parts in grand rapids Michigan before going into business with his brother. I'll ask him, if you want, about any recommendations on your transmission.but you drive dodge
my truck has 323000 miles on it now
Jealousy will get you nowhere...dikthat is dans favorite picture
So plus 90 over stock surely?work truck and stock transmission
play truck wont be though
