hoskvarna
10:22 AM
Iowa
[emoji3063][emoji3063][emoji3063][emoji3063]
Sent from Hoskey hilltop
Dream
11:22 AM
Elberton, GA
My T6 Ranger does this if the trailer has LED's. Ford sell an adapter, which when we opened one just had 120 ohm resistors added on each circuit. I ordered a bag full of 3W 120 on eeebay and just wired my trailer plugs with resistors. Buck fifty instead of $100NZD...
Man after my own heart.
Simple solution. Just requires a small amount of thinking.
11:22 AM
redline4
I'm huge in Japan
10:22 AM
Rosholt Wisconsin
You find where the battery pixies are hiding before closing mate?
Nope.
After pulling the heated seat fuses and sitting 2 hours, battery voltage was 11.8, dropped to 8.6v on start.
The next words of wisdom were to reprogram the steering column lock module with an updated calibration.
10:22 AM
Will you be able to tell its got a little bit of cam in it or will she be a smooth idle?
I'm not sure really. It's a 268 duration cam.....so it's just at the point where the centerline its ground on will be the determining factor on idle quality. It is on a 110° centerline which is mild. So....maybe.
leadfarmer
Hot Rod !!!
11:22 AM
S Central PA
Went through Gettysburg today, never was there in the snow. First pic is looking down on devils den. Second is for Kenny. 3rd is form devils den looking towards little round top. I think next is for hew Wisconsinites, and the other is for ole Blue pill himself.
Enjoy [emoji41]
Member
10:22 AM
