redline4
I'm huge in Japan
- 6:33 AM
- Mar 12, 2018
- Rosholt Wisconsin
Garbage.id rather have the older ones
im not a fan of these newer sheet metal bodied mtds
I kinda want an International 184 lowboy.exactly i work on more newer junk of others than i do of my own stuff
the hydrostatic reareends are alot of the problems as well they are weak and expensive to replace
the old cubs have cast iron gears and rearends i think the 122 weighs about 800 pounds
same transmission as my cub lo boy 154
I especially dig the sound of an old opposed Twin Onan like my Case 446 had and the Ingersoll 3016.Any pics of the wet noodle trick?
P.S. Same can be said for the motors in my opinion. Rather revive an oldie if possible. But that's just me, I like listening to the old ones run.
http://www.tractordata.com/farm-tractors/000/3/0/307-international-harvester-154-lo-boy.htmlI kinda want an International 184 lowboy.
Oh its a pile and the rod may exit so we'll see what happensId test on that pile till the rod exited.
I'm gonna rebuilded the old 10 horse over time. Im just slow. Like special kid window licker slow lolAny pics of the wet noodle trick?
My dad had a cub. First year made with all the implements and speed hitch. That got me interested in those small tractors. I really dig the 184 because it looks like 1066 ect but smallhttp://www.tractordata.com/farm-tractors/000/3/0/307-international-harvester-154-lo-boy.html
http://www.tractordata.com/farm-tractors/000/3/0/308-international-harvester-184-lo-boy.html
they are pretty much the same other than probably a different carb or governor system
the 154 is the older model and the 185 was next in the series along with different color paint
the 184 had a electric pto instead of a manual lever you pull up
the one i have has filled tires all around and rear wheel spacers that add about a inch and a half to each side
mine also has the creeper gears so you go slower and independent brake pedals
It was a joke there bud. I ruin Engines testing oil. But, it is harbor freight. I have "great luck" with their stuff.Oh its a pile and the rod may exit so we'll see what happens
i had a 1948 cub it was the second year they was outMy dad had a cub. First year made with all the implements and speed hitch. That got me interested in those small tractors. I really dig the 184 because it looks like 1066 ect but small
I know this my friend! Its all good. Im just running this mill to keep the tractor going and the driveway clearIt was a joke there bud. I ruin Engines testing oil. But, it is harbor freight. I have "great luck" with their stuff.
I sniff farts. Well my own.Good evening fart sniffers.
They say it prevents dementia. Is it true...idkI knew it.
where you been grampsGood evening fart sniffers.
we was talking tractors
you could have told us about the steel wheel machines you grew up with
