295 tramp
Hillbilly Saws
- 7:04 PM
- Dec 23, 2015
- Minnesota
Many of you know I'm building a rear handle Stihl S-10 for Dave.
Doing custom and restoration work comes with many challenges.
Working on the project tonight I ran into problems fitting the cylinder on the case.
1108 series cases I thought were all the same, unfortunately I was wrong.
The S-10 top handle and S-10 rear handle saw is built on a 08 1108 series case.
All 08 parts will fit a S-10 top or rear handle saw except the case gasket.
08 and top handle S-10 have 5 bolt holes around the fuel tank.
A rear handle S-10 has 6 bolt holes around the fuel tank.
The differences are in the cases and cylinders.
Here's a early model 08 and top handle S-10 case.
My problem at first was the jug wouldn't fit on the case.
I'm using a 47 mm jug on a early model case that used a 44mm jug.
No worries I'll just grind a little off where the jug goes into the case, problem solved.
The jug fit and all the bolt holes matched.
I thought I was home free to keep on building and then I grabbed the rear handle.
the handle has 2 bolts that fastens to the top and 1 that fastens at the bottom of the case
Hey!! there's no bottom hole in the case for the handle.
I knew at that moment I was Screwed.
Not only no hole in the bottom , the area where it mounts is wider.
Here's a 1108 series case for a rear handle S-10
Notice the same part #s like the first set of cases and it has the hole for the bottom handle mount.
It gets better.
It gets better.
