Fish
- 8:09 PM
- Jan 18, 2016
- Manton Ky.
Could also be bad gas/water in the gas, but it is hard to tell from here.......
The compression seems normal when pulling the starter, but I don't have a ton of experience judging. The rocker arms are rockering and it looks like the valves are operating. I dpn't know how to watch for compression leaking.How does the compression feel by hand? Pull the rope and watch with the valve cover off. Go ahead and try to start, and watch for compression leaking, also watch the movement of the rocker arms, etc..
Gas is fresh ethanol free. I have been running ethanol free for a couple of years. Actually since the last time I cleaned the carb. It lives outside under a tarp, but I don't think I've had water contamination.Could also be bad gas/water in the gas, but it is hard to tell from here.......
Did you pull the air filter and spray starting fluid in the cab with the choke open, and then close the choke and give it a pull, do that and then post, that will be very telling as if it starts right up you have a fuel problem.
Start with the simple stuff.
If you start it with the valve cover off, you will see if you have a blown gasket. Let the fuel dribble out of the carb into a clean jar, and then hold the fuel in the jar up and look at it. If there is any water, you'll see it.
As far as checking compression, try rotating the engine by hand backwards. If you can do it, then your compression is weak.
running only when the choked is closed and stalling when opened has absolutely nothing to do with spark...
my guess is old carb needed a cleaning/rebuild, and the new carb is either jetted wrong for that engine or like I said before, its just junk...
I saw that they both moved. Should I be able to tell just by looking? If I shot a video would you be able to see?Did the rocker arms move approximately the same distance when turning the engine over, to see if you have a worn out cam lobe?
should be completely disassembled, cleaned, and passages blown out...I cleaned the old carb, but not completely
Yeah, put up a video, if you can. Try and start it with the valve cover off too.I saw that they both moved. Should I be able to tell just by looking? If I shot a video would you be able to see?
I don't think this engine has a lot of hours on it. I got the splitter used, so I don't know for sure how many hours it had on it, but it didn't look like it had seen commercial use. I've had it for 10 or 15 years. I don't think I use it more than 20 hours per year.
PDX I looked at you vids again and read every post that you have put up the one thing that keeps coming up is how you try to start the engine! why are you trying with it at W.O.T wide open throttle? try this set the choke and just move the throttle a lil off from the stop or base about a fingers width, but before you do that run the polit screw in till i just hits bottom and out 2 full turns that is the starting setting for carb idle if it runs tune idle in or out for best idle when I say best its the fastest with the polit screw then set your base idle with the other screw and fine tune polit and it dont matter if its the oem carb or the AM carb. I like to set base idle about 1520
In those pics of the carb bowl, they look more clean than I thought it would be.
There's sometink not right, I've watched both videos again, Yeh it seems like it don't want to start, and even less with the AM carb. But it did run/tick over in the 1st vid for some time
But having said this, it's like you just go from tick over to WOT , If you slowly open the throttle the engine should slowly increase it rpm.
I'm starting to think some linkage is not conected properly, from the throttle and carb Rev regulator
We have a Honda gen and a mate has a gx160 on a tiller/rotovator ,I,m gonna have a look to see if I can see if there's anything else it could be but in the meantime there's a vid on YouTube saying and showing how to do what I said before, I will see if I can find it
And this one show how push out the other jet
