PDX Man
OPE Member
- 11:54 AM
- Jun 25, 2017
- Portland OR
My tuppence worth,
Do you leave the fuel tap on while not in use, ? What I'm about to say, can happen quicker if the tap is left on while not inuse, but can also happen but slower if the fuel tap is switched off after use.
The old carb, have you taken the bowl off, ?? If you have/haven't what does the inside look like? The reason is because when fuel sits around and evapourates, it leaves a varnish like substance. This. Can be cleaned off with a green scrubby thing. This varnish does flake off and can block the main jet, or in your case partly block it, and by using the choke. You richen the mixture and it will start but opening the throttle the air flow increases but the fuel does not.
So get a flat head screw driver and take out the jet and make sure it's clean you can use a thin bit of wire to poke out any crud or a blast of air but the wire is what I've used before.
As for you new carb, I don't think it's set up properly
I hope this helps
If you'd need help in locating the main jet. ask, but you should be able to see it in the manual
Ps I've fixed a few engines with this problem of a blocked jet
Thanks for the info. I have to admit, I usually don't turn off the fuel flow. I'll have to start doing that. The bowl has signs of corrosion, but I don't see any varnish or flaking. I'll try cleaning the bowl anyway and the main jet.
