New trailer not level
Kagy
Active OPE Member
8:03 PM
Florida
Hi all, I bought a brand new single axle 6x12 trailer several hours away from home. It was stored in a field with many more. When I got home I noticed one side sits about 3/4 of an inch lower than the other. It’s a New Generation brand and is welded nicely and seems well built. I crawled under and everything looks ok, Leaf springs look the same. Will this cause me any problems? I really don’t want to do another 5 hour round trip if it won’t cause me any trouble. Thoughts ??
ammoaddict
8:03 PM
Granite Falls, NC
Tire pressure the same? Parked on a perfectly level surface?
Kagy
Active OPE Member
8:03 PM
Florida
I did some more measurements
ammoaddict
8:03 PM
Granite Falls, NC
Im no expert that's just my humble opinion. I have a 6 x 12 trailer that I had built by a local guy (T&W Trailer) back in 2002. I have never measured it, I don't have a level place to do so. I have hauled many loads on it including some thay were way over the 3500 lb axle limit and never had any trouble except for a blown out tire. As long as you are happy with it, I'm sure it will serve you well.
8:03 PM
Likely got torqued when they welded the corners. Not enough tack welds to hold it square. Could put a heavy load on it and jack up the low corners
