twalsh341
OPE Member
- 12:31 AM
- Sep 7, 2021
- Philadelphia
Hi Everyone,
I'm new here, working on getting a clone 660 up and running. I'm planning on using this thing to mill, but also buck cants. I have another saw for limbing.
The original squish was .052", I wasn't really excited by the idea of a base gasket delete ( and when I measured squish without mine I was getting .015-.018". I turned the base down and am currently at .030" squish and think I'll keep it here unless there's a compelling reason to trim it down some more.
After the base trim, with .030" squish. I have the following timing numbers. Exhaust Crasks at 93 degrees ATDC, Duration 174
Intake opens at 79 degrees, and transfer opens at 122 degrees.
Blowdown: 29 degrees
Does the exhaust seem too low? Do the transfer ports need to be adjusted? Also you'll notice in two pictures showing the ring in place at 122 degrees to map the transfer ports that the exhaust end of the TP is slightly lower than the intake side. My understanding is that this ain't the best geometry.
I plan to open up the bottom of the transfers and blend them well, bevel all the port edges, widen the int/exh as far as skirt will reasonably allow. My questions are whether these timing numbers need to be adjusted and to where?
