Neotec 660 clone
Ronie
5:52 PM
NC
That's pretty good. My farmertec was like .060 with the gasket.
Sent from my moto g(7) power using Tapatalk
That's a lot of squish, did you end up doing a base gasket delete or left it that way?
Maintenance Chief
5:52 PM
South Carolina
If it was me , I might forgo the purchase of another cylinder, and I only say that because I've run an absolutely hideous one before with very good results.
I got an ms441 from the scrap yard and got a big bore kit from farmertech and it looks terrible, like made by a 8 year old terrible! The spark plug hole and the decomp look like they were stabbed into the cylinder with an ice pick. The bottom of the ports were almost closed with casting flash and I had to grind about a 1/4 off the outside of the ports for it to fit on the case.
Anyway I got the bare minimum accomplished to get it on the saw and its quite powerful and regularly run a 28" full comp or 34" skip on it.
You just can never tell ? And I dont know how long it'll last me ,but for 18.00 $ its already paid for itself.
Nutball
4:52 PM
Mt. Juliet, TN
Your stock cylinder does not look like farmertec to me, it appears to be chrome plated with a machined squish band and a different symbol in the center of the combustion chamber.
Ronie
5:52 PM
NC
You maybe right but the workmanship sure looks the same.
5:52 PM
I'd run it as is it might surprise you
Most of the others had excessive squish
I ran popups to get much better compression.
