My Eartquake sleeper
nenicu
2:36 AM
Romania
This was sitting by the laptop on my desk from 6 months. A 40cc italian Eartquake[Spark ] with broken coil mount bought just for the body. The engine from a 45cc mutt sold as CMI bks 45 in Germany. Has a modified Redmax 3800 case with bigger bolt spacing front to back , case impulse nipple and a crank with bigger counterweights .The jug is 42,5 mm with double open transfers. The piston has 2 1,2 mm rings[ MS 250 layout]
nenicu
2:36 AM
Romania
More
nenicu
2:36 AM
Romania
Last. The top part of the carb is original to the engine donor. The clear impulse line works ok as gas line.Impulse-will see.
6:36 PM
Got a test cut video? and nice saw. And over here Earthquake saw are nothing like that one.
nenicu
2:36 AM
Romania
The shape of the plastics is the same-hence the name. The engine is detailed in the first post. It still needs some work-it vibrates a little compared with the 37 cc engine. I'm trying next to install the original flywheel that's a little heavier than the one is on right now[37cc engine flywheel].
nenicu
2:36 AM
Romania
The next project Husqvarna 543
