My 346xp
sawmikaze
1:36 AM
steeltown
With the switch in the off or kill the saw position you should have a pathway to ground or the chassis of the saw. Start ohming it out piece by piece to find where the pathway is broken.
Since it is a NE 346 and I'm looking for one.........I'll take it offa your hands if it totally pisses you of in the end.
I aint mad at it..ive tortured that saw and it still hasnt quit on me..i think its a sign from the saw gods that its never gonna lay down...me and 2 of my friends have passed it around by the ears.
sawmikaze
1:36 AM
steeltown
Check if the blade is touching the terminal when switch is off.Does the terminal on switch button is far enough in the slot ?
Ive checked it 10 times..this saw is so aggressive it just wont shut off apparently.
sawmikaze
1:36 AM
steeltown
Use a volt meter and check continuity it's the omega symbol, put the ground to the coIL and the positive to the case it should ohm out anD beep. If it doesn't then something is up.
Dude im honestly not that into it , if i need a flux capacitor to work on a chainsaw i lose intrest
These are the tools i use.
BFH
screwdriver
Chisel
Framing gun
Wiha tool set
If i cant fix it with those i send it to someone who has the patience i dont.
stihl sawing
12:36 AM
Arkysaw
This here saw wont shut off i have to kill it with the choke..and since im not the best saw mechanic i dont know what to do.
Yes , i changed the wires and cleaned the contact area and the sumbitch just wont work..can you guys help me ?
But how do we know it is yours, I see Lavon wrote on the handle.:D
idiotwithasaw
12:36 AM
Ky
A volt meter is a very handy tool, and a continuity test is honestly the most basic of things you can do with it. It's the next step up from a wire with a light attached. But I'm a farmer and used to having to work on my own stuff. Kinda makes you a jack of all trades, or is that a jack azz, I can't remember.:nusenuse:
sawmikaze
1:36 AM
steeltown
I never had a desire to be a jack of all trades..i picked 3 or 4 things and got good at them instead of pissin around..im an average mechanic..i work on my vehicles and stuff i just really dont enjoy doin it..i get pissed too easy.
rjames
The clean beaver gets the wood
1:36 AM
Michigan
Sawmikaze be like:Looky here, baby. You're hittin' them corners too g-damn fast. You need to slow this muth@!$?ker down, you understand? I almost spilled my 'yak on this $200 suit, nugga. Come on, baby, keep it together.
346xp be like: Yeah, whatever, mutha$!#cker.
Is your name rick james ?
Mah nicca ?
sawmikaze
1:36 AM
steeltown
Say somethin else ...
rjames
1:36 AM
Michigan
I may or may not have lol'd like a dam fool when I read that.
Mastermind is a smart dude, sheep don't talk
Im gonna quit chainsawing all together and see if @Mastermind needs a hired hand holding the sheep down while he gets his bibs unbuckled..i hate my job.
sawmikaze
1:36 AM
steeltown
I think my dad has one , ill go get it
big t double
You can call me Teddy Eastwood.....
12:36 AM
My phone sucks man....
