My 346xp
sawmikaze
5:15 PM
steeltown
This here saw wont shut off i have to kill it with the choke..and since im not the best saw mechanic i dont know what to do.
Yes , i changed the wires and cleaned the contact area and the sumbitch just wont work..can you guys help me ?
Onan18
OPE Sponsor
5:15 PM
Georgia
Coil could be bad, about all it could be if the wires ohm out.
5:15 PM
I'm not a Husky guy, but I would get a new kill switch & try that. I had to put one in a 460. How it got physically broken being in an enclosed area I will never know, but I just got the saw that way, and luckily noticed a contact was missing from the kill switch.
Redfin
Meh...
5:15 PM
Central Pa
Did you put a meter on the switch? Or just touch the switch wire to the case?
idiotwithasaw
4:15 PM
Ky
If it won't shut off that just means it wants to keep cutting, and you should feel obliged to meet its demands.
idiotwithasaw
4:15 PM
Ky
In all seriousness though, make sure that no wires are unplugged or broken. May remove the coil and make sure there is no corrosion preventing a good ground. My 350 the other day wouldn't shut off, turned out the end that slips into the plastic switch had worked loose. That doesn't appear to be the problem here, but that's my experience with them.
cus_deluxe
terms of service violator
5:15 PM
Michigan
these dont have a "switch" in the normal sense. if those contacts are touching, and wires are intact then its a bad ground or somehow the coil is bad as said above.
sawmikaze
5:15 PM
steeltown
There just isnt anything stickin out as to why i cant shut the saw off..im gonna try a different coil.
idiotwithasaw
4:15 PM
Ky
It must either be the coil or a bad ground. I still say check for corrosion, or maybe the layer of bar oil and sawdust has worked under the coil and creating a layer. Who knows crazier things have happened.
ft. churchill
2:15 PM
Along the '49 trail in Nevada
With the switch in the off or kill the saw position you should have a pathway to ground or the chassis of the saw. Start ohming it out piece by piece to find where the pathway is broken.
Since it is a NE 346 and I'm looking for one.........I'll take it offa your hands if it totally pisses you of in the end.
