My 266xp rebuild
davidwyby
Rural desert logging
5:30 PM
Extreme Southeast CA
10-4, I’ve talked to them about other stuff. Still looking for a parts saw for my 2050.
I see them on fleabay from $35 and up, some with cranks. I was gonna see what shape my crank, etc. is in before I order.
Jon1212
Birch! Please.....
6:30 PM
Utah, unfortunately.....
Which 2050 parts do you need? @chainsawman2011 has a whole parts saw.
davidwyby
5:30 PM
Just like to keep one around. Misplaced a spring the other day and had to wait a week for one. Could use a couple screws...something else I’m forgetting.
7:30 PM
Cases are much cheaper than I thought, I just might. Gonna pull this thing the rest of the way down.
Got a free dishwasher or two coming ;-) got grandpas old air compressor working. Need to get an A/C unit for the garage for this summer.
Last I knew I wanted a pro saw to go between my 395 and 2050...now there are 8 chainsaws needing repair in my garage.
Sounds like you got some CAD.
7:30 PM
Guys, anyone know if a Jred top cover will fit the 266?
Maybe if the Jred cover is off a 2 piece coil saw.
This might help better.
davidwyby
5:30 PM
Yeah I moved and saws got back burnered
still in the works
leaning towards sending stuff to @Benwa and paying him for the headache
davidwyby
5:30 PM
So...I stumbled on another 266xp which seems kinda strange here in Stihl country. It’s complete but rough, I was thinking to build one from two. (This is the one I posted about with the misfit full wrap)
...but they are both apparently good enough to run, (#2 the kid said he had running for a bit) and the first one still just needs a few parts.
So I guess there’s gonna be two! Gonna have to get the serial numbers to tell them apart, or make a thread for each or something.
davidwyby
5:30 PM
Number 2 after a carb kit. Wow that was easy to kit and tune. Carried a screwdriver around all day tweaking on the 2139 and still can’t get rid of the bog.
davidwyby
5:30 PM
So the coil with good wires came off saw number one which ran with gas down the carb. I cleaned everything up to build one saw from both...good wires coil now no spark, I got it too wet maybe? Will it come back when it dries out? Or splice the good wires from it onto the one that runs with trashed wires...
smokey7
8:30 PM
Detroit
Usually the trigger module is what goes bad on the 2 piece systems. Put it in a oven at 200 or 250 for a hour or so in case water or moisture got in.
davidwyby
5:30 PM
Wow, I had it in front of a little low temp space heater. I'll try the more hotter. Thanks.
I had read about guys washing saws, thought they were more impervious...
