- 1:49 AM
- Feb 26, 2017
- Belleville, Ontario, Canada
Well I finished another saw yesterday - a 1983 154SE. It had a top fin broken so I decided to do a little porting on this one - a first for me on a saw. I ended up with 121-102-79 for numbers. I used a red97 deflector to make a dual port muffler, did a small timing advance, and bored out the air filter inlet along with the carb elbow to 11/16". Even though it is quite cold today, I HAD to see if it would run, so that's where I am now. It wouldn't start so I checked for spark and didn't see any. So I swapped coils and then I had spark. So at this point the saw was flooded but I finally got it started by holding the throttle wide open while starting it. It wasn't running super great (rich) but the saw was cold so I kept the rpms up until it was warmed up a bit. At this point it would rev super quick, but would not idle at all. After messing with the low speed for a while, I decided to switch carbs. Saw started quickly and again will rev quickly when hitting the throttle - I mean it seems to run fantastic - but if I lower the idle speed down low enough to stop the chain from moving, it just dies quickly - like you turned it off with the switch.
Saw has new air filter, fuel line, fuel filter and Denso plug. All oem parts, and both carbs were cleaned and kitted. HDA120 carb. Saw passes both vacuum and pressure test, both carbs held 12psi on inlet.
Anyone have any suggestions what to check next?
