Wonkydonkey
Plastic member
- 10:42 PM
- May 14, 2017
- Sussex, UK.
When you come to put the clutch back on, your ment to put a piston stop in and then tighten the clutch, I use a bit of old starter rope. Just put it in when the piston is above the exhaust. If you don’t put enough in when you tighten the clutch it will compress the rope and turn over. I just put a bit more in if this happens.
I’ve never had a clutch come off, except then I was in arb school and someone didn’t put in on tight enough and when I slapped the break on
it undid it self to the drum and was a fecker to get the c clip off
