MS462C - 572XP Comparison
jackjcc
3:00 PM
Minnesota
The 462 has a new style for the handle attachment spring. Instead of being parallel with the bottom of the handle tied into the case, the spring on the 462 is vertical. So they’ve made some design changes to accommodate that. I thought the 362 was a bit soft for AV, this 462 is quite stiff.
andyshine77
4:00 PM
Cincinnati, OH
2016 562. I believe it has all the mechanical updates as the current 562. 13lbs 3.0oz the tanks are bone dry.
4:00 PM
It will still be lighter than a 462. Holds less fuel and oil. I don’t cut with empty saws. Just more fuel to add to the fire.... lol just being realistic.
4:00 PM
The 461 I couldn’t even get off the ground. I need to practice getting my strength up to carry that extra weight. First I’ll start with those little pink 1lb weights they sell for women.
maulhead
2:00 PM
Home
Make sure @RI Chevy sends you a shirt after your strength gets built up!
