MS460 Magnum- Hard Starting After Storage
Steck
10:30 PM
USA
I have an early 2000’s MS 460 Magnum with factory .68 main jet. Has opened up exhaust and running max flo filter. Rebuilt the carb with a factory Walbro kit. After the saw sits for a month or two, I have to pull it a good 8-10 times before it pops over on full choke. I believe I have it tuned well and it runs well and has great power in the cut. Am I crazy or is this normal? It should be noted that after it turns over on choke but isn’t running, I can hear a bubbly, squeaky noise like air is being pulled in somewhere. Any suggestions?
Michpatriot
10:30 PM
Livonia Michigan
Carb boot or pulse line would be first on my to check list..but could be seals or crank case gasket sucking... Vacuum\pressure check will tell what you are replacing.
Steck
10:30 PM
USA
Thank you. That’s what I was thinking and makes perfect sense. It feels like the saw loses prime after sitting and has a hard time sucking fuel. After running a while and seemingly running fine, I get a rare blip in acceleration much like the sensation felt when it’s actually running dry. I will start with the impulse and fuel lines. Thank you again.
Steck
10:30 PM
USA
While we’re at it, I’m fairly new to saw repair and every repair is a learning experience for me. How does one perform such vacuum check?
Duce
10:30 PM
Roscommon, MI
Block intake and exhaust and pull vacuum from impulse line or spark plug hole. If saw has decompression, block that also.
Duce
10:30 PM
Roscommon, MI
Mini-vac or similar vacuum pump will be needed, want to hold around 7 lbs.
Loony661
462’s 4-LIFE
9:30 PM
Winona County, MN
I run a 460 as my main felling saw and it gets used almost daily. However, sometimes it does sit for a month or 2 depending on weather. With that being said, usually from a “dry start” it takes 5-6 pulls max on full choke to “pop”. Any more than that tells me your saw does have a problem - especially if you are hearing a squeal.. Like those above have said, start with the basics: Fuel and Impulse lines, and new carb diaphragms/gaskets... That’s what gets your fuel up to the carb. Best of luck!
Steck
10:30 PM
USA
Thank you all! Hopefully I get a few hours soon to take a look at it. Not much down time this winter… heating with an OWB and it’s been the coldest winter since I put it in. Lotsa wood
qurotro
Cookie Cutter
9:30 PM
Ar
8-10 is normal for saws that sit.. I would even call it good. If the saw is run daily, every cold start is 8-10 that's no good.
