MS460 jug,may need another.
lwhaples
2:15 PM
Vt
Getting close to having all the parts I need for the 460/046 I'm working on. Decided to clean the jug,knew it needed what I thought was transfer cleaned.Pic makes it show up real good. More like a pit. Junk?460 jug.jpg and yes,after sanding wasn't working a q-tip with a dab of acid.
smokey7
2:15 PM
Detroit
Unfortunatly acid was a bad move on that spot. I cant tell you if it will last as i dont know how damaged the bond to the plating in that area is now that acid was on it. Good luck
lwhaples
2:15 PM
Vt
The acid didn't eat through the plating. The chip was already there. Sand any rough edges around it and run it. The rings don't go down that far
Ah, you I like! Thanks.
