Jason628
- 5:36 PM
- Nov 21, 2020
- Washington
So I got a ms460 project that was a basket case. I ordered all the parts to get her back together. Saw came with several different coils. I cleaned up the saw and put it mostly back together but, can't seem to get spark. Threw a farmertec coil on it to get weak spark. The poly flywheel looked kinda wavy in the magnet area so I thought it may be bad. Ordered a new aftermarket flywheel and still weak spark. Tried plugs and coil from my good running 034 with no improvement. Disconnecting the ground wire makes no difference either so it's not the switch or wiring. Only thing that may be sketch is the business card air gap between coil and flywheel but, 034 I used the same card and that saw has good spark and will fire first pull almost every time. So.... I'm at a bit of a loss... Tried 3 different coils... One stihl coil that was on it and looked new and two different farmertec ones. Going to use a feeler gauge for the air gap but, I don't think it will make a difference. Idk.. Anyone have any ideas or know the resistance specs for the coil on these things?
