FOUND IT ms460/046 Tank
Trader history (4)
jacktheripper
Papa Squat
8:33 PM
Wyoming
I picked up a partially crushed ms460 that needs the following:
-Tank
-HD Filter mount and backing plate
-Air filter and cover
-Top cover
I'm going to replace bearings, piston rings, crank seals, fuel and impulse lines, etc as well, so if you have any of these laying around I'd be interested.
Thanks!
hacskaroly
2100 Fanclub Member
7:33 PM
Northern Idaho, Ehh
Good luck on this build, I worked on an 046 last year and had to replace the fuel tank too. I found the tank on Amazon for about $30.00. Duke's saws has quite a few aftermarket parts at a reasonable price.
Duke's Aftermarket Stihl 046 MS460 Parts
Edit: I think this is the tank I got - note, it will need the flippy lid and not the screw type for the fuel tank.
Fuel Gas Tank Rear Handle Housing Assembly Fit for Stihl MS460 046 MS461 Chainsaw Accessories - $31.63
jacktheripper
Papa Squat
8:33 PM
Wyoming
Thanks for the links! I had my eye on those, but keeping it OEM would be preferable. I would probably try to sell it on the forum when I'm done, I think.
jacktheripper
Papa Squat
8:33 PM
Wyoming
Changed title to reflect where I'm at now. Just needing a tank/handle now. Also would buy bearings and seals if anyone has a set laying around. I'd actually prefer an 046 tank - no flippy caps.
KcChiefs2019
9:33 PM
I have a 460 & would highly consider trading for a 064 tank handle assembly. Would have to break down tho. Just figured out what this free reving sound it's making once out of cut & no load. Pretty sure it's spun lower main.
jacktheripper
Papa Squat
8:33 PM
Wyoming
It seems like the @Woodwackr always has the parts that I'm looking for. I'm starting to wonder about this shop of his too...
But seriously, he's super generous, timely, and has the goods. 10/10.
