hseII
Heef
- 7:14 PM
- Dec 29, 2015
- West Georgia
Nice Saws.
max flow filter fit?
My bad!!!!Couldn't tell you.. I think that was TJ that was trying that, not I.
Hard to say from plug pics. I don't usually trust plugs as the only indicator; theyre part of the story, tho.Made some cuts with it again this morning. It sure sounds lean to my ears, but I don't really know what I'm talking about anyways.. Maybe it's just an Mtronic thing.
I cut a few cookies and killed the saw mid cut on the last one.. This is what the plug looked like. New plug with about 10 minutes run time. Any thoughts? I'm thinking it looks ok. I pressure/vac tested it again and all holds well. P&C looked good and were wet.
If you open up the exhaust ,i don't think you will need that plate ,it is there for the modern choked up exhaust ports .Looking at the IPL, I notice an insulating pad that goes under the muffler. Anyone know if this is made out of some common material or should I have the shop order me up one? Anyone have one from a parts machine?
#19 1138 140 9000 Insulating pad
Put the highway piston and rings in tonight. Spent all evening getting the carb, new handle and rope and everything put back together. Excited to see if it'll start I filled the tank up with gas and then watched it all leak out from a bad cap.
I took off the air cleaner and dropped a few drops of Trufuel in the carb and two pulls later, sure enough it popped! Pulled again and it idled for a second. Dropped a few more drops in with the dropper and a pull later I was idling!
I'm pretty thrilled, this is my first time replacing a piston and cleaning a bad cylinder. This started as a box of parts and I wasn't too sure I could get it put back together let alone get it to start.
I still have more to do but now I have some confidence that my time isn't wasted!
The one's I have ran seem to rev limit and not four stroke. These saws are set as lean as possible.
Yep! Might take a gander at the piston and cylinder if you aren't certain. You try moving it side to side and picking it up and setting it down to see if there was fluctuation?That's kinda what I was thinking, thanks for confirming that. No air leaks and it seems to run and idle steady so I guess I should just trust the technology and run the thing and see what happens!
Always a good sign...Congrats on a or another successful rebuild.![]()
