Jimmy in NC
- 9:02 AM
- Dec 23, 2015
- North Carolina
Just some assembly pics for those that want them.
Having been into both at this point I feel the 201 is better constructed. I like that the intake bolts on as opposed to a plastic sleeve holding it on of the 200. I feel like the carb box is easier to work in than the 200. I really like the spring AV with cable limiters in them on the 201. I also feel if working properly the electronic tuning is great in a tree on a small saw.You’re going down the same path I did Jimmy. I messed around inside the original coil (with the tester) trying to get it to relearn before I replaced it. Once running it was pig rich, replacing the solenoid fixed it. It was necessary to reset the saw after with the MDG1 in my case before getting it successfully thru a recalibration. You know, I’ve been reading that the M-Tronic 201 is making a name for itself.
Yet I still see beat up 200’s and 020T’s bringing almost $600 at suction. I’ve run them both side by side and I think they are both awesome saws. Sound different ,but both rev to 14k and have what feels to me as the same torque. I’m not a tree climber so I don’t know what they’re seeing.
Hmmm. Well we will see shortly how it does out of the box. If it needs an MDG1 it will get one attached. Ill let you all know how it does...
