Jimmy in NC
- 3:05 AM
- Dec 23, 2015
- North Carolina
MS201TC showed up today. Tree service saw purchased March of 2017. He generally does not like the saw. Last few months and it has been to two or three other Stihl shops. Everytime it comes back worse than when dropped off.
Fast forward to today...saw is to a 'No Start' condition. Quick check I pull the plug and have zero spark. I spun the motor over at 1800 rpm and zero ignition. Obviously this is where the no start comes from as the plug is wet.
Further investigation and it's only showing 105 psi on my Echo gauge designed for small plug/small two strokes. I am at 300' above sea level.
I have to pull the muffler tomorrow but I doubt it is scored. I have been told these are not super high compression but 105 seems on the low side.
I have zero experience with a 201 and minimal M-Tronic experience. Is it possible to remove the M-Tronic from this saw and run it 'traditional'? I found an old thread talking of a kit that would get me a coil, flywheel, carb that is supposed to work together. Will this kit fit this saw? Anything else I need to purchase in addition? Linkage, kill switch wiring, etc?
