MS150 carb question
redoakneck
6:14 PM
Ohio326
Is there a non plastic diaphragm for this Saw's carb??
I keep having carb issues and suspect it is that blue plastic diaphragm
Any better carb than the stock one??
redoakneck
6:14 PM
Ohio326
Seems like it keeps starving for fuel, I clean the carb, gets better for a few tanks, then same issue. I have flushed the tank. Now only using canned fuel for that saw, it is small, so not a gas guzzler
redoakneck
6:14 PM
Ohio326
Screen always looks fine in the carb
redoakneck
6:14 PM
Ohio326
Looks like tillotson hu-133A is a replacement for the zama
redoakneck
6:14 PM
Ohio326
Have you changed the filter in tank? I have replaced some that look ok but after replacing the saw would run like it should.
I will replace that too, had a batch of bad gas develop in that saw, ain't been right since
bikemike
5:14 PM
Cottage grove mn
I have found carb cleaner in the spray can can cause those parts to get stiff. I use brake clean and seems to work better imo. Has it been modded in any way?
bikemike
5:14 PM
Cottage grove mn
How many tanks of fuel has it suckEd down. The saws can be finicky when new and also they do not have the carb heat if I recall correctly so a carb can frost up in cool temps.
bikemike
5:14 PM
Cottage grove mn
You use brake cleaner for cleaning carb? I got an endless supply of that.
Yes thats all I use on diaphragm carbs now. Had a few that seemed ok before cleaning with carb cleaner. Seemed like it dried up diaphragms and didn't run after that. Had never encounter the same issue with brake cleaner yet
67L36Driver
5:14 PM
The stiff blue plastic diaphragms suck.
Actually, don't suck well enuff.
Find an old carb kit with the rubber fabric to replace it.
