Ms038 possable air leak
species8472
7:34 AM
Smithton Tas Australia
Friend got me to have a look at his 038 said it was hard to start. Cleaned out air cleaner and got it running sort of. Gave it a rev and thought what the hell.
turned the high setting back to 1 turn out to start again and this happened. Air leak? Goes from pig rich to screaming its head off.
Wonkydonkey
Plastic member
10:34 PM
Sussex, UK.
That don’t sound good,
The only real way to determine an air leak is to test it.
when you say you cleaned out the air filter, has it ingested saw dust. if it has done, it may have been eating it for some time.
While setting up for a pressure test I,d have a good look at the piston & cylinder,
Does it have good compression?
But havin said all this it just maybe the carb,
I'll be subscribing to this o_O
Cheers
Edit: I can’t help thinking I can hear some sort of knocking at lower rev/ tick over
species8472
7:34 AM
Cheers
Air filter wasn't to bad. When I get a saw its the first thing I do. Compression is very good. P and C look good just checked intake and impulse good.
Moparmyway
Its just a saw
5:34 PM
In a meeting
Put a carb kit in it
Most likely there isnt any air leak, as it returns to idle very nicely
Chances are that its just not getting enough fuel into the intake, probably from a stiff carb diaphragm
Canadian farm boy
“Normal” people scare me.
5:34 PM
Ontario, Canada
This ^^^^ plus I'd be changing the fuel filter. Might not be a bad idea to check out the condition of the fuel line while you have the carb off.
