MS 661 headache...
Tree Sling'r
2:41 AM
Fort Jones, CA
Boot: old boot no longer produced. new boot "straight boot" = 1144 141 2202 retail $20
Coil: new coil "4701 A" on the actual unit. Stihl part # = 1144 400 1420
per stihl tech
"4700 C" & "4700 D" allow the saw to go too lean. They are warrant-able. Meaning if you make a stink like it's not running right. They will replace it with the new "4701 A"
"4700 E" is good and not warrantable.
4700E and 4701A have higher fuel values than 4700c 4700d.
Reset per stihl tech -
1. start saw on choke. let it run on choke 90 seconds. switch OFF. note: I personally hold the saw and keep the chain brake off cuz the chain lets to run just a little)
2. now restart saw and just let it idle. Don't touch throttle at all. 90 seconds of idling. then switch OFF
3. restart saw and make at least 5 cuts. You will feel the saw change for each cut...kinda cool.
Good stuff, thanks bud.
