Jimmy in NC
- 10:30 AM
- Dec 23, 2015
- North Carolina
I have an 462c-m here that was brought to me for a top end. Customer [commercial tree crew] is very leary of M-tronic saws at this point as they have had several fail sooner than they expected. I told them I would pull a vac test and go through it top to bottom to ensure it is top notch when it leaves me.
When it arrived it passed a vac and pressure test with flying colors. I ordered all OEM parts to repair it and my local dealer has agreed to scan it / hard reset on it.
The saw is together at this point which included:
OEM top end
OEM gaskets
New Orange fuel pickup/filter
New white solenoid (same color that was in it)
Carb cleaned and new gaskets, needle, etc installed (passes a pressure test)
New plug
I have NOT started or even pulled the rope over more than a S-L-O-W pull. I do not want to generate any more "failed start" data than I am sure is already in there.
Now my dealer claims there is little data to be pulled from the saw's 'memory' but I think there is info there if you know how to read it. I would think if it had a fuel demand of 100% at time of failure, it would point to a fuel restriction. I'd love to see RPMs at failure (if available) to know how it was running when it cooked.
Cylinder was scored mainly exhaust side indicating a lean seize or VERY hot. Having never had the chance to see the fuel values or anything else am I expecting too much from a scan before starting? Looking for advice from those that have the software or those that have been into these more than me. I have minimal experience with any of the AutoTune / M-tronic saws.
Thoughts? Ideas?
OEM top end
OEM gaskets
New plug
Thoughts? Ideas?
