Keith Gandy
Maxima K2 40:1 87 Pump Gas
- 12:16 PM
- Dec 30, 2015
- Provencal, Louisiana
Ive had several of these AM boots go bad in short order like this
If lonewolf says its good.....its good. You just hope things have not changed by the time you need one. OEM 200T carbs are near $100- here in OZ.
Keith, I have found that many times if your 200t is eating boots then it needs new av mounts. Theses little terrors are used and abused wayyyyy beyond their intended designs and they take it...up to a point. Many kill switch wires go bad for the same reason. Bad suspension. Impulse lines go bad too many times because of age but also because there is crud jammed up under the handle. So in short, check your AV bushings.What about intake boots guys? These AM ones arent workin out? Any yall have used besides the 40$ OEM ones?
Boots should be $30 and carb $75 or so from dealer. Take 10% off my prices and that's basically list priceWhat about intake boots guys? These AM ones arent workin out? Any yall have used besides the 40$ OEM ones?
Climbers or operators that pull too hard on the saw is what breaks the mounts then the boot mostly! I used to have a climber that would always pinch the saw and wiggle it out bending the hell out of the chain. Before I saw all this going on I used to wonder why the hell the chains were breaking all the time! Another climber would always drop the saw and let the chicken line catch it and the lanyard mounts were always breaking. Another climber was always bending bars. I could do this all day!Keith, I have found that many times if your 200t is eating boots then it needs new av mounts. Theses little terrors are used and abused wayyyyy beyond their intended designs and they take it...up to a point. Many kill switch wires go bad for the same reason. Bad suspension. Impulse lines go bad too many times because of age but also because there is crud jammed up under the handle. So in short, check your AV bushings.
Well yes!thats nice to know LW... thanks for the thread and pix. i got one that I just rebuilt.... gonna test it...but it may need a carb. takes me a while to mess with the oem ones, might as well buy one of these i guess?
Climbers.....sheesh who needs em.Climbers or operators that pull too hard on the saw is what breaks the mounts then the boot mostly! I used to have a climber that would always pinch the saw and wiggle it out bending the hell out of the chain. Before I saw all this going on I used to wonder why the hell the chains were breaking all the time! Another climber would always drop the saw and let the chicken line catch it and the lanyard mounts were always breaking. Another climber was always bending bars. I could do this all day!
Saw repair guys!Climbers.....sheesh who needs em.![]()
I can't name a single climber coming in my shop (only one I had is in jail waiting for his murder trial), everyone else around me is a bucket babySaw repair guys!
Seems to be a lost art.I can't name a single climber coming in my shop (only one I had is in jail waiting for his murder trial), everyone else around me is a bucket baby
