HELP! ms 162 carb adjust
Michael Rupley
11:57 AM
Dayton Nevada.
I have not found a Stihl without an adjustment on the carb until now. I want to make this thing run well for the owner but can not find an adjustment for the mixture. Anybody know? Mike
Sloughfoot
11:57 AM
Norcal
Idle is all you can adjust on most of those small homeowner saws.
Michael Rupley
11:57 AM
Dayton Nevada.
I like that you are trying to be helpful. The fact is a saw or any other engine needs a certain ratio of air/fuel to run. Every carburetor is metered to give near this ratio. Somewhere in the carburetor is a jet (maybe fixed) that does this. I have been working on saws since 1986 and have fixed thousands. Sometimes I have had to buy special tools. Sometimes the adjustment screws were left hand thread. Some had a jet under a plug in the carburetor. So in recap any carb is adjustable, just how is sometimes problematic.
EFSM
1:57 PM
Extreme southern IL
You will not be able to make it run richer without drilling a jet. Installing a high altitude high jet will make it run leaner, but I wouldn’t do that unless you are actually at a higher elevation.
singinwoodwackr
12:57 PM
moon
If it runs the same type of carb as the 170/ 172, there IS no adjustment other than the idle screw which also acts as the Low needle. And yes, I have tried to drill out the plug on one to see if it there was a way…nope. Same deal with the older Shindaiwa 488 and some of their other small saws.
The 170 can be upgraded to a ms250 adjustable carb but I doubt it would work on the new 162.
ray benson
1:57 PM
nw indiana
This morning, a generous member sent me a 162 service manual . Check your inbox.
jmester
2:57 PM
VIRGINIA
#3 part number
1130 121 5601
Fixed jet 0.44
For these carbs
  • 1148 120 0601
    Carburetor 1148/01
  • 1148 120 0603
    Carburetor 1148/03
