monkey fest 2017
Redbull661
661 hoarder (BlueBallz)
9:02 PM
MN
Stihl 3/8ths RS 115dl new chains for each. 9pin sprocket. 36"
TM661 Velocity Stack - 33.6* 34.9 36.1 - avg: 34.9 (*added 1 sec for semi cutout)
TM661 Max Flow - 36.6 37.2 36.7 - avg: 36.8
Mastermind "El Freako" 661 Max Flow - 36.1 37.4 38.2 - avg: 37.2
well let's try 41" .404 RS
TM661 max flow - 38.5
MM661 El Freako Max flow - 40.8
- velocity stack faster than max flow
- el freako vs tm661 - speed: almost dead even! Torque: the tm661 does pull a bit harder. Which isnt too surprising given scotty is a bona fide torque hoe! :D ...maybe I'll do another comparison noodling
Redbull661
9:02 PM
MN
Freako with 10 pin and non race chain.
This saw has some serious nuts! With this setup I couldn't stuff it...I tried
When we put the race chain on you could stuff it if you pushed pretty hard
run it against scott's 64/66 same chain same bar same sprocket size
cant races...
bicycle races lol
