Darin
JACK KNOB PRICK
- 8:29 PM
- Oct 15, 2016
- DUNSMANURE, CALIFORNIA
The 075 is about 1-2 seconds faster than the Mac.
Have you ever drilled holes and then used round and flat files by hand to finish it? A 1/2" drill bit is perfect for the stihl mount and it leaves the end of the bar stud groove with a perfect half circle that looks near factory when done.Looks better than mine. I used an angle grinder with a cutoff wheel, and finished with a Dremel
No I have not but I will lolHave you ever drilled holes and then used round and flat files by hand to finish it? A 1/2" drill bit is perfect for the stihl mount and it leaves the end of the bar stud groove with a perfect half circle that looks near factory when done.
Well, I didn't think it would outperform what I had in TN, but they were a package deal that Dallas had no use for. I took videos and I think the 12 winsI can't imagine a 12 being worth a *s-word on a normal saw lol
394?Well, I didn't think it would outperform what I had in TN, but they were a package deal that Dallas had no use for. I took videos and I think the 12 wins![]()
Yerp394?
Wow
This is one stout Big Mac
With that crappy chain it was faster for sure lolOff the roll square Oregon
It was actually pretty sharp for off the roll. Corners were all good on it. I didn't have to push at allWith that crappy chain it was faster for sure lol
I seeIt was actually pretty sharp for off the roll. Corners were all good on it. I didn't have to push at all
10 pin looked like it pulled the best at the higher rpms. 12 pin faster. Cool videos man.Well, I didn't think it would outperform what I had in TN, but they were a package deal that Dallas had no use for. I took videos and I think the 12 wins![]()
I used a cutoff wheel also and a flap disc to round it. (Just the tail) everything else was on the millLooks better than mine. I used an angle grinder with a cutoff wheel, and finished with a Dremel
Looks great deetsyI used a cutoff wheel also and a flap disc to round it. (Just the tail) everything else was on the mill
I need to invest in some. When we're talking going from a 7 tooth up to a 12, at 13k rpm's that thing is moving12 pin ran good Kevin, about 25% faster in that test than the 10 pin.
Wear those chaps
