Mildly porting a 026
Micah
Active OPE Member
1:30 AM
I've got a friend's CLEAN red lever 026 torn down. Here's where I'm at I don't have the time tools or desire to to a full job, what I'm planning to do is a muffler mod, match the cylinder to the intake boot and widen the intake and exhaust. Thoughts? Opinions?
Outback
11:30 PM
Oregon
Carefully remove the bevels, set them on the bedside table, when your done with that ho tell her to put her bevels on herself before she leaves.
Outback
11:30 PM
Oregon
You grind them back in with a diamond ball when your done with the port. Maybe consider experimenting on a saw you own before you do it for somebody else........
Micah
Active OPE Member
1:30 AM
Maybe just a timing advance, muffler mod and match the intake to the manifold? I can't afford to screw anything up...
Duce
2:30 AM
Roscommon, MI
If you cannot afford replacement of parts you ruin, I would leave it alone!
Micah
Active OPE Member
1:30 AM
It's not that so much that as I just don't have time to do it twice. It's a very good friend that doesn't care what I do so long as it cuts nicely. I just always feel the need to try and squeeze as much as I can out of a saw...
Micah
Active OPE Member
1:30 AM
As soon as I get this round of stuff finished we have to get our case 1070 in the shop and split it...
Hopefully we don't have to tear in too far but I pretty well takes up the shop.
Micah
Active OPE Member
1:30 AM
So back to the saw. For a timing advance how much do you take off the side of the key and which side? Muffler mod, can I just cut the hole top to bottom into a slot? Does grinding the exhaust more cone shaped without enlarging port on the inside help? Thanks!!!
