Measure twice...
Fifelaker
1:02 AM
N. Mi.
Ms440 OEM piston
15.69 mm
39.45 mm
33.95 mm
15.24 mm
These are in the order you listed above. I have a 70e piston buried in the dung hole errr garage, I will try and dig it out later.
Fifelaker
1:02 AM
N. Mi.
70E OEM
12.96 mm
36.90 mm
31.09 mm
15.53 mm
The first three are close as the piston is domed and the skirts have a double taper.
Four Paws
Chrome won't get you home
11:02 PM
ID
70E OEM
12.96 mm
36.90 mm
31.09 mm
15.53 mm
Thanks!
What do you figure the dome height is? 2.50mm ?
Fifelaker
1:02 AM
N. Mi.
My calibrated eye says about 3.20- 3.25mm. I measured three times and it is close.
