Mcculloch sp125/101b kart saw build thread
Bigmac
10:02 AM
Drop the pop off pressure to 8 pounds and a five psi hold it helped a tiny amount to be richer but not crazy and it still acts like it wants to run out of fuel if I hold it open for a long period of time
I did do a pressure VAC test when I installed everything, and it passed with flying colors
sawfun
10:02 AM
Portland Oregon
I hadn’t put a barn chain on yet, more of just a sound and feel thing at that point, I just put my 32 inch test bar on, and I can get it to idle just below the clutch engagement but every once in a while it’ll hang just a hair above and spin the chain. I think I’m going to lower the pop off pressure and see if that makes a difference, I have both screws turned 2 turns out it still wanted to run out of fuel on the top, The only other thing it could be is my impulse inlet end of the manifold is a little bit small, not sure if that’s enough to affect it either
Ok, the reason I asked was after receiving my 090 back from Randy he had told me that the clutch was engaging at idle. Sure enough it was without a bar and chain. In fact you could hardly stop it with a long 2×4 against it. I was hesitant to put a bar and chain on it but took it to a gtg with a 72" bar & chain where I knew I'd have some experienced help. The saw behaved normally, but take the bar and chain off and the clutch runs fully engaged. These high powered big saws seem to need a bar and chain to pull them down. Though I'd have thought my 2×4 pressure was a lot more of a drag than a chain.
Bigmac
10:02 AM
Thanks Don, I have experienced that on one of the 125’s the chains would spin on the 36” bar a little bit but not the 50”at all! I think this will be fine with a 50” at idle. It’s getting closer, but still have some bugs to work out!
Bigmac
10:02 AM
Not sure if I’m just gonna have to upgrade the entire fuel system get a bigger fuel line fuel filter and even more free-flowing vent as well, I can’t believe how much fuel I burn through just messing around a little earlier I threw the bar and chain on and cut into a stump, the saw ran hard, but wanted to run out of fuel after about 5 seconds WOT, it also burned over a 1/3 of a tank of fuel!!
sawfun
10:02 AM
Portland Oregon
Well at least you know your likely making some horsepower. Now as for the EPA, ha ha ha.
Bigmac
10:02 AM
Been thinking about it for a while. The odd thing with this carb is I can get it to idle and rev once with it set at one turn out on the l an h screw, but if I old it open it screams. With it 2 turns out on both it was better but I had to turn in the butterfly screw to get it to idle, but it ran well like that, could rev it hard three to five times and it then start to over rev. Then I adjusted the pop off to 8psi, it then seemed richer everywhere...but it I reved it up 5 times it sounded rich.. so I held it wot for 5 seconds then it cleared out and over reved. I am thinking it’s more restrictive fuel delivery, or my impulse barb on the manifold. I will try the barb tomorrow. Think I will call terry too, I got the carb from him, he might have some advice
sawfun
10:02 AM
Portland Oregon
Calling Terry sounds like a proper plan. I had a larger fuel line (1/4") on my BDC saw. I had the saw at an infamous builder and he put it back to the stock one, and did not understand why I did what I did. In racing cars, you always want an much supply as possible on the intake side on the fuel delivery system, be it carb or injection. CR & KX 125's have a larger line than the stock 125's macs do. I haven't got it running, nor tried since I got it back from him some time ago. I kinda expect fuel delivery issues when under a big load. I ran that saw when it was pig rich a few years ago and wouldn't rev over 6000 rpm. The carb needle lever position made almost no difference, however spring pressure did. The carb came with several length springs, I tried the next longer length spring and the saw started and ran like you would have expected. By the way, even pig rich and blubbering, it cut faster than my strong 125c at full rpm. I tried it in a log with a 36" bar buried just to get it in wood.
Bigmac
10:02 AM
What were you using for a pickup filter for the 1/4 line?
Bigmac
10:02 AM
I called Terry, he didn’t feel the fuel line was an issue, he also didn’t think the impulse was an issue but he also said to make sure the impulse is the same size as the carb barb, so I will do that first. He said to drill the high speed next, he was surprised but said it must need more.
So I will redo the impulse setup then drill the carb if needed
he was glad I adjusted the pop off pressure, he said it was too high, but also said it wouldn’t make a huge difference, he confirmed the carb was designed for 1.5 turns out and 1/8 turn on the h, he basically said if your at 2 you need to drill
Bigmac
10:02 AM
OK, I feel like an idiot! It looks like my impulse Barb going into the intake manifold was clogged! I can’t believe it even ran! It was so plugged it would barely flow air at all, It would likely run fine cleared out, but I’m going to put the larger Barb on, Hoping this will fix my problems! LOL
It looks like a piece of Loctite from when I installed the barb originally,The weird thing is I was able to pressure vac test it and it free flow then, it must’ve broken loose and lodged itself in the 90 once I got it running
Bigmac
10:02 AM
Got it up and running again! Now I can smoke out the neighbors! LOL it’s gonna take a little while to dial the carburetor in, but now it’s plenty rich
