Stihlbro
- 3:42 AM
- Dec 29, 2015
- Virginia
Are you trying to keep the pressure under what the pop off is for this test or just slightly over?
Really need small pressure under the metering diaphragm. If the needle and seat is sealing it would put pressure on the pump side. If it leaking by the pressure goes under the metering diaphram.
If the carb won't lean out closing off the needle adjustments, it's bypassing some where.
Joey
