Terry Syd
- 4:51 AM
- Jan 18, 2016
- Comboyne, NSW Australia
Randy, something Poleman and I ran into was the jet having a 'valve' under it, that is, a small thin piece of plastic. It seems to be an EPA thing as I have run into them on a number of carbs.
The jet you took out of the EL-42 could give you an idea if it has the 'valve'.
If it has the valve, you don't want to push the film out of place by pushing the drill too far into the jet, it might block the outlet of the chamber. Just take it easy as you drill out the last bit of the jet so that the drill doesn't 'plunge' through the jet and into the film.
EDIT: We both have drilled holes through the film, dislodged them and run without them - and didn't notice any difference. However, they could be important in some carbs as they may act like the valve in the main discharge nozzle to keep the air from flowing into the wetside when the engine is idling for a long time.
