bpmaas
- 11:35 PM
- Oct 21, 2023
- midwest
I'm stumped.
Symtom : engine dies when choke is opened (can only keep it running by holding butterfly almost closed). No amount of adjustment to high speed jet helps. Removed carb applied pressure to fuel inlet...holds pressure. Did a complete teardown of carb. Submerged it completely in fresh non/oxy gasoline for a day. Squirted gasoline into all passages, witnessed no blockages. Pump diaphram was good, so reused. Replaced metering diaphram. Replaced needle and spring. Reinstalled on saw...no change.
Deeper teardown: intake manifold, didn't find a problem. Put vacuum to the impulse hose, held. Fuel tank emptied and flushed. Replaced fuel filter. Tank vent removed, inspected (fine).
Mystery: with a full fuel tank (carb off) I can put the saw in any position, including upside down and fuel barely leaks out of hose. Apply a tiny amount of air to tank vent and fuel sprays all over?
I didn't check manifold with vacuum or pressure. I didn't check crankcase with vacuum or pressure.
The saw is super clean, in like new condition (I suspect very low hours).
Can anyone tell me what is likely the cause?
