Makita 6401 w/BB melted impluse line
Gravedigger
10:39 PM
Fair Hill, MD
the Makita wouldn't idle so I started vac/pressure testing. Found the impulse line had melted off by the cylinder. I had used a blue tygon fuel line.
Reading on OPE found Stihl 200t impulse line 0000 937 5004 being used.
Is this the best impulse line to use?
Lone Wolf
10:39 PM
Nj
The Stihl line is good Tygon not good. Is it the same ID line? If so use it as long as it fits tight.
10:39 PM
Tygon sucks years ago when it was the craze i bought some and had failures within month's.
Stihl and echo bulk is all i use now 3x5mm and 3x6mm for over 5 year's no problem.
Gravedigger
10:39 PM
Fair Hill, MD
And it should not be touching the cylinder directly I would say.
It melted off at the nipple.
Went to the Echo dealer and purchased 3 feet of each at 1.50/foot. I'm back up and running.
Nitehawk55
10:39 PM
Ontario
There is good and bad line out on the market , avoid Chinese made at all costs . Chinese rubber line and even tygon (if it really is tygon) is crap , I've seen it fail in short order .
I've got Tygon made by St. Gobain(sp?) who also makes lines of all different types from medical to who knows . It is excellent line .
That line you have there Gravedigger is plastic , not tygon . Plastic does not like heat .
Gravedigger
10:39 PM
Fair Hill, MD
The line didn't last long. Ordered the Stihl impulse line.
Nitehawk55
10:39 PM
Ontario
Could there be a reason it's getting so hot at the impulse ? , doesn't seem normal but I'm not familiar with that saw either .
Saw been ported or modded in any way ?
Gravedigger
10:39 PM
Fair Hill, MD
Nipple is on the jug. I'm pretty sure I used the wrong type of tubing. The Stihl tubing feels more heat resistant.
The saw mods are only bb kit and hd12 carb. Will be doing mm once I get it running regularly.
Nitehawk55
10:39 PM
Ontario
Don't know what to tell you but getting that hot at the impulse still seems odd .
Try the Stihl hose , if it cooks you know somethings up with it . A MM would likely make it run cooler .
10:39 PM
Happened to me too, as I stated a few posts back. Tygon melts off the cylinder nipple. I replaced it with echo line and it's been fine for 2 years.
