Making A Walbro HDA-199 Fit On A 262XP
Pugsley555
4:59 PM
Fairview
That you brandon?
Yes sir it is. Ive been trying to find a alternative to the hda-87 for the crankcand cylinder that I bought from you, I'm not sure I told you but either someone from ab site or this one offered me a 87 for $100. Iwas thinking about it but first I wanted to see if there were any other options and ran into this thread.
I'm in NC tonight but should be back home in SC by tomorrow night then I can post some pictures of the 212 hopefully by tomorrow night. Thanks again fellas
3:59 PM
The 191, 198, or 199 will work with the mods in this thread. Some others may as well .
Pugsley555
4:59 PM
Fairview
On the right is the hda-144 on the right is the hda-212. The port for the impulse lines up right. I just had to swap the choke rod and the plate went on fine. The 212 is a bit taller but it doesn't seem like it's gonna interfere with anything?IMG_20190211_144131020.jpg IMG_20190211_144105243.jpg IMG_20190211_144052044.jpg IMG_20190211_144131020.jpg IMG_20190211_143916150.jpg
wcorey
4:59 PM
ma usa
The big question as to whether it's worth swapping is what's the size of the venturi and throttle plate on the 212.
Reloaderguy
2:59 PM
Intermountain West
I'm bumping this thread to thank everyone that contributed over the years.
Here are a couple of relevant links that I think add context and options to the 262XP conversions:
I did the conversion first using a used 199A I sourced from Ebay. The accelerator pump in the 199A ended up being bad. Rather than gambling on another used 199A, I found a new 174 for $60 on Ebay. The 174 isn't an EPA carb and doesn't have the pump. The conversion is easier and the rods spin freer since there isn't drag from the pump. I assume the 190 and 198 feel the same. All of the conversion parts interchange. The 174 has choke plate limit stops like the 199A and 198.
Tor R
Novice, Leg model #2
10:59 PM
Mandal
There are three versions without the acc pump, 198 is one of them.
These are much easier to rebuild to 262 than those with the acc pump.
Remember to massage the impulse hole in the carburetor since it does not match the boot gasket perfectly.
This applies to all 3xx carburetors for the 2xx series, the small cubic ones like 242 etc too.
Reloaderguy
2:59 PM
Intermountain West
Do you know if anyone ever tried putting the main jet from a 175/191/199 carb into a 174/190/198? All documentation says the EPA carbs have a larger main jet. The main jet is still available.
Tor R
10:59 PM
Mandal
It's been so many years since I last built 357 carburetors to fit 254/262 carburetors, but if my memory serves me right, the 199/191 is the one with the biggest jets, was surprising to see but it is what it is.
Even I bought alot jets I never swapped and tested.
Reloaderguy
2:59 PM
Intermountain West
Mine was pretty close and I didn't end up touching it. I got the saw in wood today and didn't have any fueling issues.
The converted 174 was much easier to tune than the 144 and 120 carbs I have.
wcorey
4:59 PM
ma usa
For what it's worth here's a pic of an hd 12 I adapted to a ported 262. Was 8-10 years ago and I don't recall many details other than it worked well (and still does).
