M-Tronic Question Is now solved !!!!
Gary Courtney
2:05 PM
Froglevel
I just put a 362 c-m together. Complete new oem bottom end. Used the carb and coil off the crushed 362. Did the default and run in wood for 10 minutes. It comes out of the cut and idles beautifully. When I kill it and then repull to crank it takes 2 to 4 pulls to crank. Then idles good and will scream in the wood. Kill it and 2 to 4 pulls later starts back up ? Troubleshoot! Please! Has new 1140-440-3010 harness.
Spladle160
3:05 PM
NOVA
Long shot but maybe a weak impulse? Did you happen to check the opening on the new crankcase?
Gary Courtney
2:05 PM
Froglevel
try the "mechanical" stuff first.... maybe tank pressure valve? Try opening the tank before re-starting next time just for chits and giggles. Then watch the carby linkage smoothness in operation. Seen a few get "bound up" or slightly off kilter and "hang" up.
Did vac/pressure test on case and passed. Did vac and pressure test on tank and passed.
angelo c
Coal Member
3:05 PM
follow through all the "mechanical" linkages for the carby...Choke/ accelerator "block" throttle rods ect. they are funny and sometimes get placed "off" a hair when rebuilding the entire system. ask me how I know... :)
Ketchup
Epoxy member
1:05 PM
Colorado
No pop at all on the first pulls or almost starts?
DND 9000
9:05 PM
Germany
Only the orange one is availible since the change in 2018, except you get old stock white ones from your dealer.
